E100-0002 in IRADVANCE C2020H in the new machine during instal
  • ps/pcl
    TECH SPECIALIST
    • Jun 2008
    • 35
    [Error Code] E100-0002 in IRADVANCE C2020H in the new machine during instal
    when i switched on the mc for first time i got the the jam code 0CF1 as soon as opened right door assy and closed it .was E100-0002 error code.Restared the machin many time same symptom appearing(0cf1 & E100).Checked the Laser unit connections & Checked fuses in AC driver PCB. any help on this pls.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: E100-0002 in IRADVANCE C2020H in the new machine during instal
    It's sounds like you need to replace the Laser Scanner Unit.
    • ps/pcl
      TECH SPECIALIST
      • Jun 2008
      • 35
      Sorry It is E110-0002
      • zoraldinho
        • Mar 2008
        • 5015
        Scanner Motor movement error or motor control error
        1.Check the harness/connector between the DC Controller
        PCB (UN09) and the Laser Scanner Unit
        2.Check the flexible cable/connector between the DC
        Controller PCB (UN09) and the Laser Scanner Unit
        3. Replace the Laser Scanner Unit
        4. Replace the DC Controller PCB (UN09)
