e840 -0001 in ir 7105
  • rooshan
    • Jul 2011
    • 6
    [Error Code] e840 -0001 in ir 7105
    can anybody help to solve this problem
    after jaming paper the error will be come when it warming up
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: e840 -0001 in ir 7105
    The home position is not detected when the sensor is moved up/down (i.e., the
    sensor
    has not gone off).
    Disconnect and then connect J508, J552, and J553 of the DC
    controller PCB. Disconnect
    and then connect J4001 and J4002 of the fixing inlet sensor
    ascent/descent motor driver
    PCB; as necessary, replace the fixing inlet sensor ascent/
    descent motor. Replace the fixing
    inlet sensor ascent/descent motor driver PCB.
    • rooshan
      • Jul 2011
      • 6
      thanks for the reply .. i am try to do that now
      • zoraldinho
        • Mar 2008
        • 5015
        good luck
        • rooshan
          • Jul 2011
          • 6
          dear friend i try all work what u mentiond earlier. but the prolem is still there...
          • V-P
            • Apr 2011
            • 679
            how many copies has the machine ?
            In some cases the motor should be changed, even if you think it is ok.
            • charm5496
              • 2387
              The Fixing Inlet Sensor/Motor Driver pcb FM2-5065-000 could also cause this error...also check your frame side connector for cracks and bent pins
              • rooshan
                • Jul 2011
                • 6
                hello friend,
                i change the motor , sensor and checked the conectors. but the problem is still there. i dont know wht to do............. please help me
                • charm5496
                  • 2387
                  Did you try the PCB yet?
                  • rooshan
                    • Jul 2011
                    • 6
                    thanks for ur reply ... i change the Dc board. and the mechine is ok now.... now having the problem with v2 finished when give the central stapling option the paper come cross.. help me plzzz
