Installation Image Press C1 + Image Press Server Q1
  • luizpolli
    • Aug 2025
  • teckat
    • 16083
    Re: Installation Image Press C1 + Image Press Server Q1
    see pdf>>>>>>>>Canon ImagePRESS Server Q1-
    go in service mode
    COPIER>OPTION>INT-FACE
    Connecting Setting of External PDL Controller
    set to "3" power off/on
    check connection/Ping ??
    install Print Driver ???
    E-MAIL/I-Fax needs- Color Universal Send Kit> activated by registering a license
    key.
    • luizpolli
      Hello Teckat,
      I did all these steps and nothing.
      Do you have the USER MANUAL for ImagePress C1?
      I appreciate for the ImagePress Q1 manual, he's very importante for us.
      Thanks a lot
      • teckat
        • 16083
        U mean u can not ping your IP Address ?????
        does the print driver see the C1 ???
        Can u make copies off the glass ???
        see guide----
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 5015
          Now You have all documents thanks to Teckat.Step by step!!
          • luizpolli
            Thanks a lot.
            The print problem has been solved.
            Now how do i use the scan on ImagePress C1?
            • teckat
              • 16083
              Originally posted by luizpolli
              Thanks a lot.
              Go on control panel & put your C1 > Online
              • luizpolli
                Hello teckat,
                I did, and now how can i receive the scanner on my comp?
                • zoraldinho
                  • Mar 2008
                  • 5015
                  Teckat have a meeting at this moment.Read this link.It's wery similar.
                  http://www.copytechnet.com/forums/ca...ht=scan+online
                  • luizpolli
                    Let me check.
                    I appreciate Zoraldinho
                    • teckat
                      • 16083
                      Let me check.
                      check your PM for C1-Sending Guide
                      • luizpolli
                        • zoraldinho
                          • Mar 2008
                          • 5015
                          On the copier select scanner and set online.Bee shore to have instaled color scangear.
                          • luizpolli
                            Yes i've installed COLOR SCANGEAR V2.71. It's set to online, but My imagepress C1 does not have SEND options.
                            • zoraldinho
                              • Mar 2008
                              • 5015
                              Send option dont work different way.You need a software to get a file.Read again link for ir 2200.
