Error Code Canon IR3025
+ More Options
Posts
  • jackkmmg
    • Jun 2011
    • 2
    [Error Code] Error Code Canon IR3025
    can any one help me with error code e000024-0101 which appears on the screen thats canon IR3025
  • spectraindo
    • May 2008
    • 313
    Re: Error Code Canon IR3025
    Check the cable from the developing unit.
    • jackkmmg
      • Jun 2011
      • 2
      already check and replace the sensor still the same.
      • mr.daus
        • Apr 2011
        • 98
        replace the toner motor
        firdaus +(62)8195002007 firdaustrish@ymail.com
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 5018
          When the above-mentioned symptom occurs, remove the Toner Sensor and clean the Toner Sensor mounting
          area on the Developing Assembly Container and the Toner Sensor. Then, mount the Toner Sensor again so that
          it is placed in parallel with the Container. Be careful to ensure toner is not trapped by the Sensor and the surrounding
          area is clean. Or, replace the Developing Assembly with the one for which production process is
          changed.
          Factory Measures:
          Change production process of the Developing Assembly to prevent the Toner Sensor from being fixed askew.
          This measure shall be implemented for the Developing Assembly from LOT No. 50506xxx or later.
