Canon ir5570 error
  • xadiey
    • Aug 2025
    [Error Code] Canon ir5570 error
    What the problem machine for this code E000001-0010, E000001-0001, E000732-0001, E000733-0001.These machines often have to code. when I reset the machine back in operation, but will be back problem. What is the real cause of this problem.
  • gensys
    • Jan 2011
    • 323
    Re: Canon ir5570 error
    E001-0001=error or an open circuit in main termistor,shutter or sub thermistor
    remedy >>>> chek conector of each termistor for any fault in connection & wiring (check or replace termistor)
    E001-0010=
    COPIER>FUNCTION>CLEAR>ERROR
    The Road will be Mastered by >>> the Going...
    • teckat
      • 16083
      E000001-0010=The power has been turned off and then back on without resetting the error.
      - Reset the error. (COPIER>FUNCTION>CLEAR>ERR)
      E000001-0001=There is an error or an open circuit in the main thermistor, shutter thermistor, or sub thermistor.
      - Check the connector of each thermistor or any fault in
      connection and wiring.
      - Replace the thermistor in question.
      - Replace the DC controller PCB.
      E000732-0001
      =There is a fault in the reader communication./There is a DDI-S communication error.
      - Check the communication between the reader unit and the main controller.
      - Check the power supply of the reader unit. (Check to see if initialization takes place at start-up.)
      - Replace the reader controller PCB,reader relay PCB, or main controller PCB.
      E000733-0001=There is a fault in the printer communication./There is a DDI-P communication error.
      - Check the connection of the cable between the DC controller and the main controller.
      - Check the power supply of the printer. (Check to see if initialization takes place at start-up.)
      - Replace the DC controller PCB or the
      Service Mode
      1) Press the asterisk key (*) on the operation panel.
      2) Press 2 and 8 simultaneously on the numeric keypad.
      3) Press the asterisk key (*)on the operation panel.
      COPIER > FUNCTION > CLEAR>ERR
      Use it to reset an error codes
      1) Select the item, and press the OK key.
      2) Turn off and then on the main power.
      WARNING
      Be careful what u clear/ only use it on error codes if u have no experience on CANON PRINTERS
      • gensys
        • Jan 2011
        • 323
        E732-0001= Usually highlights when there is a problem to the DDI-S communication
        remedy >>> check all jammper on the reader unit & main controller, check power supply of reader unite
        • gensys
          • Jan 2011
          • 323
          For E732 & E733 >>> teckcat allrady posted
          read >>> warning
          • gensys
            • Jan 2011
            • 323
            The theme is closed
