USB Media for IRC 5035i
  • mark121381
    • Jul 2011
    • 85
    [Misc] USB Media for IRC 5035i
    Hello,
    I have issue regarding to the usb media of IRC 5035i. I can't view the files from my usb device when i connect it to the usb media port beside of the control panel. Is there any settings need to enable on the system settings or Service mode? and also I found usb cable inside of the control panel, you will see it when you slide the control panel and by removing the front cover of the reader. Is there any connection on it? or is it must be having connection on the usb media so that it will work on it? Thanks in advance!!
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: USB Media for IRC 5035i
    If your model advance series go in service mode level 2,find disp-sw and ui-mem set to 1 and restart the machine.
    COPIER>OPTION>DSPLY-SW>UI-MEM
    • charm5496
      • 2387
      Originally posted by mark121381
      Hello,
      The extra USB cable is for an option and has nothing to do with the USB port. Did you enable the port under settings/registration?
      Settings registration>preferences>display settings>store location settings>turn memory media to 'ON' and recycle the power is all you need to do to enable the port from factory.
      • mark121381
        • Jul 2011
        • 85
        Thank you Sir zoraldinho and sir charm, now its working.
        • mark121381
          • Jul 2011
          • 85
          Sir where it is located? is it under of system settings? I will try to look this options so that in case our salesman need to know this. we dont need to teach him in service mode. so that can prevent any changes he can possible made...thanks
          • teckat
            • 16083
            to add on some info>>
            imageRUNNER ADVANCED C5030 / C5035 / C5045 / C5051 / C7055 / C7065 / C9065 PRO / C9075 PRO
            The following type of memory media is supported:
            • USB memory
            • The following memory media file system is supported:
            • FAT32
            • Memory media with security functions and memory card readers connected via USB are not supported.
            • Memory media used with an extension cable is not supported.
            • Memory media used via a USB hub is not supported.
            • Memory media that does meet the USB specification is not supported.
            • Some memory media cannot be used.
            • When using memory media, the machine may not enter the Sleep mode completely. Weekly Timer settings are also disabled.
            • charm5496
              • 2387
              Just follow the path that I typed up. There is no need to go into service mode for this option. We turn them all to 'ON' before it leacves our office.
              • mark121381
                • Jul 2011
                • 85
                • USB memory
                • FAT32
                Thank you sir for the additional info sir. it is very helpful...
