ir5870c image fault
  • hamdyyassin
    • 84
    ir5870c image fault
    my copier canon ir5870c in the mornning gives a ghost image after auto gradation once or 2 times the image is ok
    i have this problem in all copiers for this model ir5870c
    thanks for help
  • teckat
    • 16083
    Re: ir5870c image fault
    where are these printers located ???
    post a copy of the issue-
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5018
      Check high-humidity environment
      Service Mode > COPIER > DISPLAY > ANALOG > ABS-HUM
      Use it to check the machine inside humidity (environment sensor; in %RH).
      Reason for Teckat question about location i believe.
      • teckat
        • 16083
