ir3300 - E602-0003
  • kuby
    • Oct 2007
    • 1409
    ir3300 - E602-0003
    I know it is the hard drive and know how to reload the firmware and everything. But when I go to the machine I notice the cassette heater switch is turned ON. I have turned it OFF and next call I get the switch is turned ON again. I put a clear plastic cover over it and still it gets turned ON.
    My question is there a setting on the machine that can automatically turn the switch ON? And if so how do I disable the heater all toghther?
    Also I noticed a removable Fuse on the board for the switch, what is the fuse for?
  • Northwestservice
    • Jan 2011
    • 140
    Re: ir3300 - E602-0003
    in north america there are no cassette heaters and the sw does nothing.
    • kuby
      • Oct 2007
      • 1409
      Well with the cassette heater switch (that is what it is called in the manual) it also turns on the lens heater and the mirror heater. It gets the back of the machine hot just about where the hard drive is and ends up damaging the hard drive.
      And I just found out if your remove the fuse then you can not turn on the items.
      • teckat
        • 16083
        Just disable SW2
