IR3045
  • jiongpao
    • May 2009
    • 413
    IR3045
    Hi anyone,
    I have 2 cases here. May i know the error code message for e024 for ir3045?
    And the other ir3045 can on theres a yellow power light but theres no display on control panel. Power supply and control panel changed no cure. Any solution or possibility?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: IR3045
    Originally posted by jiongpao
    Hi anyone,
    E 00024
    Replace the developing assembly toner sensor.
    Connect the connector. Replace the DC controller
    PCB.
    no display
    Did your machine turn full on ??
    Check DIMM SD-RAM WA7-4625
    Check hard disc
    • teckat
      • 16083
      Re: IR3045
      Hi anyone,
      if u still have no power/no display
      see this Document-----No Power-No Display-CP LED On RMT1 Checks.doc
      • jiongpao
        • May 2009
        • 413
        Re: IR3045
        Thanks will feedback the result
