E068 - 000 on iR 105
  • Dedy.P
    • 67
    hallo guys, please help, my copier got an error code E068 - 000
    (don't have the service manual yet)
    Thanks in advance
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: E068 - 000 on iR 105
    E068 The high-voltage output has a fault. (separation charging assembly)
    A fault (leak) has been detected while the separation charging assembly is
    being supplied
    with high voltage.
    Remove and mount the transfer/separation charging
    assembly. Disconnect and then connect
    J7233 and J734 of the HV-DC PCB. Disconnect and then
    connect J741 and J742 of the
    HV-AC PCB. Replace the HV-AC PCB. Replace the transfer/
    separation charging assembly.
    Replace the pre-transfer charging assembly.
