Noise when feeding card stock 11x17 thru canon ir adv c5051
  • tecolote
    • May 2025
    [Misc] Noise when feeding card stock 11x17 thru canon ir adv c5051
    Unable to determine cause of this noise if anyone else has come across this plkease respond
  • kuby
    • Oct 2007
    • 1374
    Re: Noise when feeding card stock 11x17 thru canon ir adv c5051
    What kind of noise? Is it a popping because the card stock does not bend very easy, or a paper feed roller noise because of the thickness of the card stock and it is having a harad time with it?
    • tecolote
      The noise seems to be a grumbling,drive gear type that only occurs when running heavy paper regular 20 lb makes no noise. Mostly this would occur when using the bypass tray but in this case they were running it out of cassette #3
      • vigour
        • Aug 2010
        • 1038
        i think it is somewhat normal
        i have heard that noise on a few at Fedex Office.
        i thought it strange but i was working on other models.
        • charm5496
          • 2387
          could be the fixing film as it is the root of most odd noises from this unit. But running a stock of that type through the cassette can cause all types of issues since it will be going faster than it should through the unit and through a feed path that wasn't designed to handle that thick stock.
