Error Code 751-9000
  • George_H
    [Error Code] Error Code 751-9000
    the canon IRC 4840 gives the error code E 751-9000 and stop continuing the start up process everytime i turn the machine on.
    i checked the power suppy, it is workin properly.
    what other causes could be behind this Issue???
    Pease help
  • charm5496
    • 2387
    Re: Error Code 751-9000
    Pease help
    The copier displays E751-9000 at power on.
    Workaround :
    Slide out the bypass assembly and check the internal connector J750 and the bypass connector J755 for damage.
    If necessary, replace the damaged connector.
    Open the door and turn the unit on to see if the copier will boot up. If you get a close door message close the bypass and see if the unit errors out again.
      • 16083
      Pease help
      Here is a pic from charm5496's reply
      Can't tell u how many frustrated customers damage it/ slam unit in looking for a jam
      • George_H
        You are completely right, the connector was broken, i replaced it, machine worked perfectly.
        thank you guys, you are the best.
          • 16083
          seeing is believing
