irc5185i df jam 0094 on display
  • macuk
    • May 2009
    • 90
    Via the df paper will not feed at all and green light flashes. It will not reset until the machine is turned off and on again.
    Have sens init but with no success.
    I have a manual for the copier but not the df. any ideas?
  • vigour
    • Aug 2010
    • 1038
    Re: irc5185i df jam 0094 on display
    http://www.copytechnet.com/forums/ca...-feeder-2.html
    5075 etc, use the same feeder
    • teckat
      • 16083
      A 0094 Jam code is caused by any of the feeder sensor being blocked, when the print button is pressed.
      First clean all of the sensors and initialize the sensors in Service Mode > FEEDER > FUNCTION > SENS-INIT.
      If jam still occurs check the sensors in Service Mode > I/O.
      Service Mode > COPIER > I/O > FEEDER.
      Check the following sensors to see which one is in a High state. Replace the sensor that indicates paper is present.
      SENSOR PORT BIT READING
      PI1 0001 1 1: paper present
      PI1 0004 5 1: paper present
      PI5 0005 2 0: paper present
      PI11 0006 5 1: paper present
      PI12 0001 3 1: paper present
      PI12 0006 3 1: paper present
      PCB2 0004 5 1: paper present
      0007 11111111: no paper
      PCB3 0001 0 0: paper present
      0008 11111111: no paper
      PCB4 0001 2 0: paper present
      0009 11111111: no paper
      Part number for PCB 2,3, and 4 is FM2-1022-000
      Part number for PI 1,5,11,and 12 is WG8-5593-000
      PI 7,8,9, and 10 are for size detection only
      Below is a diagram of where the sensors are located
      reminder----Post Separation Sensor PCB2
      /part number FM2-1022-000
      the Sensor Holder does not come with the new PCB2 Sensor Unit and you would need to remove it from the old unit and snap it on the new unit. If misplaced, the sensor holder is available as a service part. The part number is: FC5-3131-000
      • macuk
        • May 2009
        • 90
        Thanks for all the info guys. I found that the cable from the scanner to the machine was not quite made properly. I remade the connections and Hey Presto! doc feeder now works!
