imageRUNNER 2525/ 2530/ 2535/ 2545-(Measure to Prevent a Solid Image)
Pub. is to notify the field that when replacing the main controller PCB assembly, a
RAM Clear should be performed to prevent a solid image.
When replacing the main controller PCB assembly [1] listed in the service parts list at the end of this
Pub., a RAM clear should be performed according to the following Service Mode
procedure.
see PDF>>>TP11.pdf
procedure.
see PDF>>>TP11.pdf
