Error code 315 d
  • bineshpaul
    • Jul 2010
    • 43
    [Error Code] Error code 315 d
    Dear all,
    In My IR6570 machine shows error code E 315 d. pls tell me the solution.
    Thanks in advance
    Regards
    Binesh
  • mr.daus
    • Apr 2011
    • 98
    Re: Error code 315 d
    Originally posted by bineshpaul
    Dear all, In My IR6570 machine shows error code E 315 d. pls tell me the solution.Thanks in advanceRegardsBinesh
    COPIER - FUNCTION - CCD - CCD_ADJ - OKplace oryginal paper on platen glass (10 blank)
    firdaus +(62)8195002007 firdaustrish@ymail.com
    • mrfixit51
      Lead Service Technician
      • Oct 2008
      • 1975
      I don't believe CCD Adjust has nothing to so with this,,, I fought this for quite awhile on a iR3320 years ago. It has to do with image data error on the main controller. The resolution to my long fought battle was to replace the memory on the main controller...
      Good luck!
      • adhy
        • Feb 2011
        • 109
        try to replace the SDRAM on main controller. hope this help.
        • teckat
          • 16083
          Dear all,
          Thanks in advance
          Regards
          Binesh
          If u have a Fiery S1 Connected make sure
          the setting of Image Control is set to "4" in service mode -
          Service Mode Level 1 ( * 2 / 8 * ) > Copier > Option > INT-FACE, highlight IMG-CONT, select 4, press OK.
          Cycle the main power switch for the change to take effect.
          or>>>>>>>>>>>>>>>>
          Try performing a hard drive clear for '0'
          To perform a hard drive clear:
          1-Enter service mode level 1 by pressing Additional Functions 2 / 8 Additional Functions,
          2-Select Copier > Function > System.
          3-Next, select CHK-TYPE and press '0'.
          4-Finally highlight HD-CLEAR and press ok.
          Note:Always power cycle the machine after performing service mode adjustments
          • gensys
            • Jan 2011
            • 324
            Dear all,
            Thanks in advance
            Regards
            Binesh
            There is an IMAGE DATA ERROR
            There is a fault in the image data.
            - 0007 There is a JIBIG encode error.
            - 000d There is a JBIG decode error.
            >> Turn off and then back on the power.
            Or replace memory
            The Road will be Mastered by >>> the Going...
