Optional Power Supply Unit
  • Atta
    • Jul 2010
    • 26
    Hello Guys,
    Thanks for the wonderful support you are given to us (the freshers in the copier field), I have a serious issue at hand and i need a help badly. the issue is I have completely assembled IR2535 and it's working find,but i couldn't attach the inner finisher because I don't know where to fix the Optional power board that came with the finisher. I know it might sound funny but guys I spent hours on the new equipment trying to locate where the board can be fixed. I was able to fixed the finisher perfectly but I don't know where to fix the Power Unit. there is no manual attached to the Power Unit, i have the machine working without it now. can someone help me out Please ,,,,,,,,,, Thanks.
  • teckat
    • 16083
    Re: Optional Power Supply Unit
    Originally posted by Atta
    Hello Guys,
    The inner finisher B1 ??
    InnerFinisher B1 INSTALL.pdf
    LOCATION OF OPTIONAL PS PCB. BELOW
    1) Remove the rear cover (right).
    2) Remove the rear cover (left).
    3) Remove the lower rear cover.
    4) Remove the option power supply cover
    - 2 claws
    INSTALL IT/the option power supply PCB.
    WITH - 2 screws/& PLUG IN 3 CONNECTORS
    PUT BACK THE COVER !!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    • Atta
      • Jul 2010
      • 26
      Good work done, I will give it a try and get back to you. now I am not near the machine.
      And will let you know the out come. Regards, and all the best thanks again.
