iR3045 error e-020 Toner problem
  • Tim C
    • 167
    This problem, I found the developer unit to be completely out of toner. E-020 code occurs.
    Replaced the toner hopper assy, didn't help. There is a toner bottle drive unit (white box) I put one
    in pulled from a iR3570 looked similar still not turning the toner bottle..Any suggestions
  • teckat
    • 16083
    Re: iR3045 error e-020 Toner problem
    Replace the Controller Power Supply PCB.
    This PCB provides 3.3v, 5v, 13v and 24v to the DC Controller.
    The part number is FM2-2764-010
    • mrfixit51
      Lead Service Technician
      • Oct 2008
      • 1975
      I just put a toner hopper into a 3035 2 weeks ago.
      The bottle would not turn by itself. With all the covers off I moved the bottle assembly front to rear while I could hear the motor trying to drive the bottle, and it would engage sometimes, and not other times. I replaced the entire hopper assembly, ( I was too ill to want to figure this one out, I just wanted it fixed), and the new unit worked as is it was supposed to without my intervention...
