canon toner
  • Lasersupplies
    • Jul 2011
    • 221
    canon toner
    The toner in hp mono cartridges can be used in multiple models, for example toner in a 2100 printer
    is the same toner in a 4100 printer. I have a question for canon techs or other knowledgeable techs.
    Is canon mono toner basically the same across all models the containers being the only thing that is different?
  • livancicm
    • Sep 2008
    • 96
    Re: canon toner
    no
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3944
      Re: canon toner
      Absolutely not!!
      • teckat
        • 16083
        Re: canon toner
        NO'`````````````````````````
        The specific polymer used varies by manufacturer but can be a styrene acrylate co-polymer, a polyester resin, a styrene butadiene co-polymer, or a few other special polymers. Toner formulations vary from manufacturer to manufacturer and even from machine to machine.
        Typically formulation, granule size and melting point vary the most.
        • V-P
          • Apr 2011
          • 679
          Re: canon toner
          That is such a good explanation.
          I remember being in a HP training some years ago (when I was still doing HP) that the trainer showed us a transparent plastic bottle of yellow.
          I shaked it and I could swear it was liquid. Turned out it was toner.
