Information about Ir 4570,3570
  • top101
    • Jul 2025
    Is this good for copy center that can produce at least 500,000 copies per month with consistent performance?? Is this unit using a fusing film or fusing roller? thanks in advance
  • spectraindo
    • May 2008
    • 313
    Re: Information about Ir 4570,3570
    Forget it, iR4570 is an office machine with 55.000 /month duty cycle, using fixing film for fusing.
    • top101
      thanks spectraindo... can u suggest an IR series which uses rollers as fusing. at least 40-60 cpm...
      • mr.daus
        • Apr 2011
        • 98
        don't use IR4570 for copy service,,
        get IR6570 / IR5000/6000 / IR5075 for best productions
        firdaus +(62)8195002007 firdaustrish@ymail.com
        • KenB
          Geek Extraordinaire
          • Dec 2007
          • 3944
          None of the machines mentioned in this thread can run 500k/month, or even anywhere near that number.
          That is a LOT of prints - are you sure that's an accurate number?
          If your volume truly is that high, I would suggest at least two machines, more like the iR105, that is if you're looking for used equipment.
          • teckat
            • 16083
            Kyocera
            • Herrmann
              • Jan 2006
              • 792
              Teckat, you forgot the KM Bizhub Pro 1051
              A real workhorse which find it most comfortable if running all day
              If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
              • teckat
                • 16083
                I'm a Canon Dog, but I have seen the Pro 1051 in action/
                Canon only wishes they can build a Finisher like that
                • spectraindo
                  • May 2008
                  • 313
                  Teckat that Bizhub in the video is printing slowly ,maybe 50 cpm?
                  Why not suggest an iR7105 ? I've just finished working on an iR7105, looks like a fine machine.
                  Running 20.000 prints without replacing the Toner Cartridge, just like the iR105 with a better finisher.
                  • teckat
                    • 16083
                    both have the same similar Speed
                    but this PRO 1051 would kick the 7105 out to sea with it's better performance options
                    toner bottle yield is about 80,000 prints on the Pro
                    Printer specifications
                    bizhub PRO 1051
                    Print speed A4
                    Up to 105 ppm
                    Up to 6,300 pph
                    Print speed A3
                    Up to 60 ppm
                    Up to 3,600 pph
                    iR 7105Digital Multifunctional Imaging System
                    105ppm (A4),
                    50ppm (A3)
                    • gensys
                      • Jan 2011
                      • 323
                      bizhub PRO 1051
                      Print speed A4
                      Up to 105 ppm
                      Up to 6,300 pph
                      Print speed A3
                      Up to 60 ppm
                      Up to 3,600 pph
                      105ppm (A4),
                      50ppm (A3)
                      I with the big desire and delight would work on the iR7105 - it something another
                      Canon U.S.A. : Support & Drivers : imageRUNNER 105+
                      Duty Cycle 600,000 Impressions per Month
                      In the relative world to speak subjectively - it is absurd
                      The Road will be Mastered by >>> the Going...
                      • gensys
                        • Jan 2011
                        • 323
                        I have 60000-65000 copy & print on the iR 6570 without replacing the Toner Cartrige
                        I printing & copying 200000-350000 in month
                        It is necessary is thin to adjust the machine
                        • top101
                          thanks a lot guys ... can you suggest 35-50cpm in any brand? In our country we used to buy and sell refurbished machine and servicing it for free, as long as customers is buying parts and consumables from us.. I worked on canon IR 400 for almost 4 years and this gave me good profit and less technical problems... This models are already obsolete. so, I'm starting to learn what brand and model I will purchase... thanks in advance..
                          • gensys
                            • Jan 2011
                            • 323
                            Then unambiguously a canon`s mashine>>> iR5570/6570,
                            50ppm & high mashins is without problem
                            • spectraindo
                              • May 2008
                              • 313
                              In the range of 35-45 cpm. from Canon the choice is iR3570, iR4570, iR3035, iR3045, iR3235, iR3245.
                              About the fixing film used on the new machines, you must learn how to repair it, it's not difficult.
