Part numbers for IR ADV 50xx
    Does anyone have the part numbers for the fixing (230Volt) and transfer belt assemblies.
    My parts manual show them as NPN
    • 16083
    Re: Part numbers for IR ADV 50xx
    Why would u replace the entire Fix Unit ??
    the 230v fix film # is listed
    u replace parts as needed !!
    FY7-0408-000=Part Number for the New ITB
    ITB_TP10 003a[1].pdf
    ITB_TP10 142c[1].pdf
    • iRC
      Summer trainee!
      • 96
      The fixing unit cannot be bought as an assembly. Or that's what we were told when we asked the PN from our local Canon HQ.
      The ITB assembly has a part number but it's considered as an "secure item". So when you are ordering the ITB assembly, Canon will ask the serial number of the device where the part is needed. If someone here knows, It would be nice to hear why is this part a "secure item"?
      -iRC
      Edit: Teckat was faster
        • 16083
        Originally posted by irc
        the fixing unit cannot be bought as an assembly. Or that's what we were told when we asked the pn from our local canon hq.
        The itb assembly has a part number but it's considered as an "secure item". So when you are ordering the itb assembly, canon will ask the serial number of the device where the part is needed. If someone here knows, it would be nice to hear why is this part a "secure item"?
        -irc
        edit: Teckat was faster
        secure for warranty control
        counterfeiting
        / Fbi_man.JPG
        shine an LED flashlight beam on it and examine it closely with a magnifying glass. You might be able to see the small, scattered yellow dots printed there that could be used to trace the document back to you.
        The dots' minuscule size, covering less than one-thousandth of the page, along with their color combination of yellow on white, makes them invisible to the naked eye. One way to determine if your color laser is applying this tracking process is to shine a blue LED light--say, from a key-chain laser flashlight--on your page and use a magnifier.
          [ATTACH=CONFIG]11086[/ATTACH]
          [ATTACH=CONFIG]11087[/ATTACH]
          Thanks for the info.
          I don't normally replace assemblies my service manager asked for the part numbers.
