IR4570 replace emulator disk
  • madu132
    • Dec 2008
    • 65
    Recently I got IR4570 machine...
    After I install the driver PCL5 on computer, I am confuse because the machine only print after spooling finished. I already set the driver setting to print immediately. I also already tried to reinstall the driver.
    When I check on Remote Utility, I saw the drive is only 200 MB. And when I check the hard disk on the mainboard, its said HD emulator.
    So, my question...
    If I want to replace it with real hard disk 20/40G is it possible?
    what else I neeed beside the disk and the system software?
    do I need specific disk or I can change itf file on this system?
    thx
    • 16083
    Re: IR4570 replace emulator disk
    4570 Has to have a Real HD & not an HD emulator
    4570 HDD.ift file is Encrypted/
    u need to buy same HDD in printer or an OEM
    • madu132
      • Dec 2008
      • 65
      from SPC I found the disk type is HTS541020G9AT00, I already purchase it from online store. Now, the next thing I need is the system software. Teckat, could you share the SSW for 4570? thx
        • 16083
        check PM
        • madu132
          • Dec 2008
          • 65
          check PM
          thx Teckat, you're ROCK
