IR5000i
  • mr.daus
    • Apr 2011
    • 98
    [Misc] IR5000i
    My customers IR5000i
    when I turn it on, normally as usual.
    when ready, the display panel lights off but panel power is light.
    I try to replace the RAM memorybut still, after a while I try to switch back to normal and then place the screen turns off, I try to turn off the main power and turn back, the screen is not only the flame of the lamp power alone.
    helpful suggestions
    firdaus +(62)8195002007 firdaustrish@ymail.com
    • 16083
    Re: IR5000i
    helpful suggestions
    check connector Main Controller J1012 for a loose connection.
    check 5 volts from J1018B-pin 3
    are fans on ?
    is power light green ?
    does printer power/heat up ??
