Touch Panel dont work on Imagepress C1
  • COCODIAZ
    • May 2010
    • 31
    Hello i have a problem with a C1 imagepress , the touch panel dont work, but there isn't a error code. the keyboard, work ok.
    Thanks in advance
    cocoDIAZ
  • charm5496
    • 2387
    Re: Touch Panel dont work on Imagepress C1
    Thanks in advance
    cocoDIAZ
    have you pulled the control panel apart to check the connections. You might need a new LCD
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5007
      If you have old control panel unit FL2-2616,replace with new one FL3-1063
      Also need to replace Inverter PCB Assembly with new one FK2-7408
      • teckat
        • 16083
        Thanks in advance
        cocoDIAZ
        is your touch screen locked in MEAP display
        here is the PDF on-Service Part Changes for the LCD Control Panel Unit and the Inverter PCB Assembly
        imagePRESS C1 CUF00001-CUF00592
        (All Serial Numbers with TKW Prefix)
        TP08-1.pdf
