IR 2200 Help
  • ganesh_bbr
    IR 2200 Help
    Hello All,
    I am completely new to copiers.
    I have a IR 2200 copier and i remember seeing additional buttons on the LCD display in a 8000 series copiers for 4 on 1 copy option.
    Is there a way i can add this in my 2200 as well ?
    If possible please help on doing this.
    Ganesh
  • teckat
    • 16083
    Re: IR 2200 Help
    Originally posted by ganesh_bbr
    Hello All,
    Ganesh
    on Control Panel>press [Special Features] → press [Image Combination].
    Select (Image Combination)
    This mode automatically reduces two, four, or eight originals, two-sided originals, or the facing
    pages of a book to fit on one side or both sides of a selected paper size.
    IMPORTANT
    • When the machine is operating in the Image Combination mode, you cannot use the Entire Image, Two-sided, Two-page Separation, Cover/Sheet Insertion, Booklet, Transparency Interleaving, Saddle Stitch, Original Frame Erase, Book Frame Erase, Different Size Originals, Image Separation, Image Repeat, or Mirror Image modes.
    • Originals copied in the Image Combination mode must all be the same size. You cannot use the Image Combination mode with the Different Size Originals mode.
    NOTE
    • The reduction ratio is automatically set so that the originals fit on the selected paper size.
    2 ON 1 - Reduces two one-sided or two-sided originals to fit on one side or both sides of the copy sheet.
    4 ON 1 - Reduces four one-sided or two-sided originals to fit on one side or both sides of the copy sheet.
    8 ON 1 - Reduces eight one-sided or two-sided originals to fit on one side or both sides of the copy sheet.
    How to use Image Combination Feature:
    1. Place your originals and press the [SPECIAL FEATURES] key.
    2. Press the [IMAGE COMB.] key.
    3. After selecting the type of original, press the [OK] key.
    4. Select the desired Image Combination feature, then press the [OK] key.
    5. Select the copy paper size, then press the [OK] key.
    6. Press the [DONE] key.
    7. Proceed to make copies the usual way
