IR 5055 issue
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    IR 5055 issue
    Some advise guys.IR 5055 light stripe every 50 print.Machine have new coronas.Counter is around 1 000 000.See pdf
    2798_001.pdf
  • teckat
    • 16083
    Re: IR 5055 issue
    [ATTACH=CONFIG]11243[/ATTACH]
    Check the interior Drum Heater ????prevents condensation on the photosensitive drum
    address-P012-bit 2/drum heater ON signal= 0:ON
    Check if Environment switch (SW3) is on ?
    controls drum heater
    in LEVEL 2
    COPIER > OPTION > BODY
    DRM-H-SW Use it to enable/disable the nighttime drum heater.
    0: enable drum heater
    1: turn on/off drum heater in keeping with environment (default)
    2: disable drum heater
    • zoraldinho
      • Mar 2008
      • 5007
      Re: IR 5055 issue
      Something like that??
      see PDF...ir6570-002.pdf
      • teckat
        • 16083
        Re: IR 5055 issue
        • zoraldinho
          • Mar 2008
          • 5007
          Re: IR 5055 issue
          Developer clutch solve my problem.Thanks.
