Canon Imageclass MF8350CDN Error E194-000
  • tibbs
    • Aug 2008
    • 225
    Hello friends, i have a canon Mf8350 thats giving me an error E194-000. Am not sure what the problem is, can anyone with knoledge of this machine share information about this problem?
    Tibbs
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: Canon Imageclass MF8350CDN Error E194-000
    Error in CPR sensor
    CPR sensor does not function normally
    Cause:
    Dirt on density sensor, problem in
    density sensor / DC controller PCB /
    toner cartridge
    Check DC controller PCB connectors
    Replace ITB units
    Replace DC controller PCBs
    Replace toner cartridges
    • tibbs
      • Aug 2008
      • 225
      Thanks for your reply, do you happen to know where this sensor is? cause i don't have a manual for this machine. If you do have one can you send me a copy? my email address is john@progresscom.net.
      • drewzif
        • 101
        I have this same error. I am guessing it's caused by the compatible cartridges. Any idea how to determine which one may be the problem? The error is intermittent.
        • gksapple
          • Apr 2014
          • 116
          [ATTACH]32583[/ATTACH]
          have a look on the attachment
