Jam 010B - Possible combination advice needed to check.
  • mezerwi
    • Aug 2010
    • 58
    [Jamming] Jam 010B - Possible combination advice needed to check.
    Hi,
    Got this error code 010B on IR8500. Checked almost everything but the problem still exist.
    During jam, paper tend to be halfway at fixing unit.
    Any idea guys?
    Anything that should I focus on?
    Mezerwi
  • vigour
    • Aug 2010
    • 1038
    Re: Jam 010B - Possible combination advice needed to check.
    010b delay to inner delivery sensor (ps9)
    fuser rollers
    cracked fuser gear
    a nick in the sensor arms--you have to feel for it with your fingernail
    bad fuser drive motor
    clutch behind the fuser motor.
    rollers and one way gear and bearings just after the fuser (if the lead edge gets that far)
    • mrfixit51
      Lead Service Technician
      • Oct 2008
      • 1975
      fuser rollers
      cracked fuser gear
      The best part I like in vigours answer is the fuser drive gear,, the internal lug gets broken off and the gear will slip around the fuser roller sometimes, and drive the roller correctly sometimes.
      • vigour
        • Aug 2010
        • 1038
        mrfixit
        I am replacing one of those gears right now for 010b.
        talk about timing
        • mrfixit51
          • Oct 2008
          • 1975
          mrfixit
          talk about timing
          Was the lug broke off, or did the gear break in two??
          Not sure if it is good or bad timing on that one,
          not too bad if you have the gear onhand though...
          • vigour
            • Aug 2010
            • 1038
            lug was broken
            i had the gear
            1.5mil so installed the fuser kit
            • mrfixit51
              • Oct 2008
              • 1975
              Good call!! You have to split it open anyway...
