what are the meter counts?
what kind of monthly volume are you going to run on the device?
What kind of stocks are you going to be running?
Do they both have the options on them that you need? Print, Fax, Send etc.
The 4570 is a newer machine, but not as "heavy duty" as the 6000. Both are good, but the 6000 is limited in the fuctionality that can be added to it as you can only add print to it. The 4570 can be made a true multi-function unit.
the 4570 is easier to work on. but you will have fewer maintenance issues with the 6000.
