imagepass s1 v2.0 ????
+ More Options
Posts
  • alexctx
    • Dec 2010
    • 158
    imagePASS S1 v1.0, 1.1 ir7105v1 MN 40.06 BOOT 2.21C prints ok
    imagePASS S1 v2.0 ir7105v1 MN 40.06 BOOT 2.21C prints ??????
  • its_just_a_copier
    • May 2011
    • 132
    Re: imagepass s1 v2.0 ????
    Hola amigo
    Looks like your IR7105 should be at V2...latest MNCON I've got is v80.02
    A bit out of date...
    • teckat
      • 16083
      SEE PDF>>>> v80.02.02 V2 for the imageRUNNER 7086-7095-7105 and 7095 Printer V2_ TP09_389a.pdf
      • alexctx
        • Dec 2010
        • 158
        I know that should update the iR7105.
        what happens is the team. this 19 hours of travel and the client just sent the imagePASS s1.
        because the system is wrong.
        I have installed the s1 the vercion 2.0 because I have only that.
        the question is whether this vercion. S1v2.0 and
        iR7105 mn40.06 the boot v1 2.21c. will print??
        • charm5496
          • 2387
          yes the S1 will work the machine V2 system software
          • alexctx
            • Dec 2010
            • 158
            S1 V2.0 works with iR7105 v1 MN40.06, BOOT 2.21??
            • charm5496
              • 2387
              here is the TP for version 2.1 on the S1 imagepass. looks like you will be fine.
              TP06 256[1].pdf
              • alexctx
                • Dec 2010
                • 158
                here says s1v2.1that working with iR7105 v1MN30.08, BOOT 2.21
                conclude that S1v2.0 iR7105 v1 works with MN30.08, BOOT2.21 to more.
                thank you very much for the help
                • charm5496
                  • 2387
                  good luck!!!
