hello to everry body, i want to know about the system softwares of the following models are same or different? ir4570/3570/2870/3530/2230. when i change the ir 3530/2230 as a printer can i use ir4570 series priter bootrom and hard disk?if not i want to know what are the similarities and differences between those models. i have no seperate manual for ir3530/2230. can any one help me? thanhs in advance.
ir4570/3570/2870/2270/3530/2230 system software
Re: ir4570/3570/2870/2270/3530/2230 system software
Why don't you attain some knowledge in Service, before requesting information on swapping parts
read my quote below,so u will understand my answer.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
thanks mr. teckat .i did not swapped any thing from ir4570 to 2230. i have some knowledge how to change the copier as a printer. i already note your posts before. i am your fan. a customer ask me to change his ir2230 as a printer. i know that i should put an one more 128mb memory. but my qustion is can i use ir4570 printer bootrom and hard disk? after your reply i will start my work. thank you.Comment
FK2-4907-000
HDD,HTS541640J9AT00
OEM HD is the same
Copier Boot Rom is different between 2230 & 4570
imageRUNNER 2230/2830/3530 =FM2-3803-500
imageRUNNER 2270/2870/3570/4570 =FM2-4837-000
Printer Boot Rom from kit E2-E3 !!
P = UFR II (This boot ROM & SSW is included in the UFR II Printer Kit E3.)
H = UFR II and PCL (This Boot ROM & SSW is included in the UFR II/PCL Printer Kit E2.)
SEE>>>>>>>>>>>>>TP05 049[1].pdf
The iR2230/2830/3530 will only work with a total of 256 meg of memory installed.
If it has a 256 meg. DIMM already installed, do not install the additional 128 meg. DIMM. One way to check the memory in the copier is pull it out and look at it. It should have a sticker on it that indicates the size.
or Another way is to go into the service mode.Last edited by teckat; 08-15-2011, 03:33 PM.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
thanks mr. teckat .i did not swapped any thing from ir4570 to 2230. i have some knowledge how to change the copier as a printer. i already note your posts before. i am your fan. a customer ask me to change his ir2230 as a printer. i know that i should put an one more 128mb memory. but my qustion is can i use ir4570 printer bootrom and hard disk? after your reply i will start my work. thank you.Accidents don't just happen. They must be carelessly planned.Comment
Part # 9906A009AA UFR II Printer Kit-E3 -Sales Dept.
Part # 9592A004AA PCL/UFR II Printer Kit-E2 -Sales Dept.
Part # WM2-5216-000 iR HD**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
I need Firmware for IR3530.
Kindly send it to me.
mail: rajacs41@gmail.com
thanks.Comment
The person here in charge of frimware is Helen Waite. So if you want frimware, go to Helen Waite. She'll handle all your needs.
HtH
Paul@justmanuals.com
HtH
sir,
Till now i did not get the system software.
kindly send me, if some one have firmware for ir3530.
send manuals for ir3530 and ir400.
thanks.Comment
sir,
thanks.“I think you should treat good friends like a fine wine. That’s why I keep mine locked up in the basement.” - Tim HawkinsComment
pomoykin
Friends, I really need firmware Canon iR2270, cause E602-0001.
Help me, please.
I so far away from any service centersComment
Another 1st poster that needs something. Everybody is your friend when you need something right? How much are you willing to PAY?Comment
