IR 8105
  • Gerry.Fitz
    Product Specialist
    • Oct 2008
    • 16
    [Misc] IR 8105
    Hi I have a Canon 8105 that will not feed from the post inserter..all other systems work
    any ideas chaps
    Gerry
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Re: IR 8105
    Any jam or error codes?
    • Gerry.Fitz
      Product Specialist
      • Oct 2008
      • 16
      Re: IR 8105
      no...no codes and m/c carries on as if nought has happened on ver 30 firmware
      Gerry
      • vigour
        • Aug 2010
        • 1038
        Re: IR 8105
        TRY V 40
        was the whole unit upgraded? each piece might not have had the latest firmwre, therefore a mimatch somewhere.
        try mmi and/or dc con clear
        some 6000 and 8000 accessories are different, double check that
        • mrfixit51
          Lead Service Technician
          • Oct 2008
          • 1975
          Re: IR 8105
          Also thought of this while driving today, if you look at a print driver that prints to this copier, does it show up in the picture of all the "toys" that are loaded onto the copier?
          • teckat
            • 16083
            Re: IR 8105
            do not attempt any CLEARS > without printing out settings first
