Canon IRC3220 control panel freeze after boot up
  • Rohan
    • Aug 2011
    • 4
    [Misc] Canon IRC3220 control panel freeze after boot up
    Hi copytechers!
    We bought a 2nd hand canon IRC3220 with fiery interface.
    The machine freezes on start-up - the normal Canon start-up screen displays, followed by the normal control panel except that the screen will not respond to touch nor will the keypad. I can access to service menu for while then freeze. The message on the screen says "The printer is warming up" & touch screen is frozen.
    Does anyone have any bright ideas?
    Cheers
    Rohan
  • teckat
    • 16083
    Re: Canon IRC3220 control panel freeze after boot up
    Originally posted by Rohan
    Hi copytechers!
    Cheers
    Rohan
    you mean u have a Fiery imagePass C1/2 install on rear of printer ?
    if so - power off printer & Fiery
    remove all connections -Communications cable /Cross Ethernet cable & Power cable from Fiery to Printer
    then power up printer
    and get into service mode as quick as possible/ may take a few tries
    get into COPIER>OPTION<INT-FACE>IMG-CONT & set it to "3" hit OK & power off printer
    replace all Fiery connections/ if Fiery has a Power Switch leave it off/ if not don't worry/
    Power up Printer/ when u see splash screen bar almost finished/switch on Fiery if it has a switch/if not bypass this step/
    Your printer and Firey should eventually boot up/ These C1/2 Fierys are a pain in the but-
    Depending on Fiery model, on newer ones EFI did away with the switch for Canon
    Either way, always shut down the Fiery using the Control Panel under the Printer Tab, follow instructions on Shutdown method
    • Rohan
      • Aug 2011
      • 4
      Thank you vey much TECHAT. You have solved my copier issue. It is working well now. You have saved me $$$.
      • teckat
        • 16083
        ELVIS.jpgthanks, & good luck
