ir3300 fax ring delay
  • sgcopiertech
    • Jun 2025
    [Misc] ir3300 fax ring delay
    Hi, 1 line is split as a telephone and a fax line connected to an ir3300, whenever an incoming call (not a fax transmission) is receive, the phone line will ring only twice and then transfers the call to the fax line.
    anybody knows how to extend the ring before the FAX/TEL switch?
    thanks!
  • charm5496
    • 2387
    Re: ir3300 fax ring delay
    1.Enter service mode on the copier and enter the Fax Service Mode.
    2.Select NCU.
    3.Select Auto RX.
    4.Highlight '007'and change the setting as desired. The default setting will be 02.
    • sgcopiertech
      solved my problem! thanks!
      I was not able to get this info on the service manual, it was stated:
      #4: NCU: (disabled for service)
      All setting under this item will collectively set in response to the #5 TYPE setting.
      • charm5496
        • 2387
        awesome. glad you got it the way you want it.
