i have this canon irc 3750 when you switch it on you see only the green light, no display on the screen, no warming up it stays dead, do any one have idea on. i will be glad to get solution thanks.
canon irc 3750
Re: canon irc 3750
pull the rectangle off the rear cover and check your connections on the main controller, reseat your RAM and boot rom. You might need to replace the RAM and/or boot rom.Accidents don't just happen. They must be carelessly planned. -
Re: canon irc 3750
The All-Night Power Supply protection circuit may be shutting off power to all loads.
The RMT1 and RMT2 signals are used to trigger the protection circuit and disable the power supplies.
SEE .DOC>>>>>No Power-No Display-CP LED On RMT1 Checks.doc**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
