imgepress c1
  • alexctx
    • Dec 2010
    • 157
    imgepress c1
    developer spills
    first was black.
    after a week was cyan.
    imagePRESS C1 series: TKW 00336.
    System Software V66.04
    Boot ROM V55.03
    Language V66.04 (JEFIG) *
    RUI V64.03 (JEFIG) *
    Cont MEAP V61.00
    Pre App Install V3.60
    DC-CON V21.01
    R-CON v8.01
    SDICT V20.04 (J) *
    KEY V2.01
    V40.04 browser
    Help V60.02
    Web DAV V60.01
    Media V42.02
    FIN_AA1/AA2 v5.01
    DADF - R1 v5.01
    Punch V5.02
    V10.06 TTS (E J) *
    ALL V66.04
    ALL_HDF V66.04
    HD Format V00.09
    Starter was new bk, c, m, y.
    New Drum, atr, new, new frame sensor.
    itb new
    units revealed:
    BK: k000011036
    C: c000002277
    M: m000002261
    Y: y000002267
    has the following problem.
    TP08 183a.pdf
    Date: 05-26-08
    not in the failure of such units newsletter.
    TP09 446b.pdf
    Date: 03/05/10
    units will become damaged revealing?
    or come factory like that.
    or maybe the card is damaged dc
    Has this happened to them.
    Tell me your experiences please
  • teckat
    • 16083
    Re: imgepress c1
    Unless u are/or work for a Canon Authorized Dealer > they will not honor any product returns posted on tech.pubs.
    Do u use CANON OEM Developing Assemblies ?
    are u using OEM Developer , when and if u are doing Dev.changes ?
    Mylar becomes damaged/ causes Spillage Issues/
    Environment & Printer locations contribute greatly to these Developer issues
    if u don't use the OEM Developer/ other third party starter is unstable
    old saying >
    "u make your bed/now lay in it"
    It means
    >that the mistakes you made created the problem or put you in the situation that you are in and you need to figure out the correct way to fix or solve the problem you are facing your self since you made the choices that put you there to begin with .
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5009
      Re: imgepress c1
      What kind of spills?Post a pic please.
      • alexctx
        • Dec 2010
        • 157
        Re: imgepress c1
        we changed the units seem to do well have printed 3300 and is well.
        • teckat
          • 16083
          Re: imgepress c1
          [ATTACH=CONFIG]11506[/ATTACH]
          like I said>> Mylar becomes damaged/ causes Spillage Issues/
          known issue since model came on line
          • zoraldinho
            • Mar 2008
            • 5009
            Re: imgepress c1
            1) Check the version of DCON. If it is v21.01(iPRC1) or v7.01(iPRC1+) or earlier, upgrade it to the latest one.
            (The following control in service mode is added changed in v21.01(iPRC1)/v7.01(iPRC1+) or later.)
            2) Set "3" in service mode > COPIER > OPTION > BODY > DEVL-VTH.
            3) Check the color where developer overflow occurs. If it occurs in black only, go to step 4); if it occurs also in
            other colors, go to step 6).
            4) Set "54" in service mode > COPIER > ADJUST > DENS > P-TG-K.
            5) Set "30" in service mode > COPIER > ADJUST > DPC V-CONT > VCONT-K and go to step 8).
            6) Set "54" in service mode > COPIER > ADJUST > DENS > P-TG-Y/M/C/K.
            7) Set "30" in service mode > COPIER > ADJUST > DPC V-CONT > VCONT-Y/M/C/K.
            8) Replace the concerned developing assembly or developer.
            9) Clean the ATR sensor.
            10) Execute aging.
            Set "5" in Service mode > TEST > PG > TYPE.
            Set "1" in Service mode > TEST > PG > TXPH.
            Set "0" in Service mode > TEST > PG > THRU.
            Set "128" in Service mode > TEST > PG > DENS-Y/M/C/K.
            Set "1" in Service mode > TEST > PG > 2-SIDE.
            Set "20" in Service mode > TEST > PG > PG-GTY PG-QTY.
            * Use A3 or larger paper.
            11) Run automatic gradation correction (full correction).
            When replacing the Starter for the Developing Assembly.
            14) Mount the Developing Unit to the host machine in the removing order in reverse.
            15) Turn on the Main Power Switch.
            16) As soon as the screen is displayed on the Control Panel, select the following Service Mode: COPIER >
            FUNCTION > INSTALL > AINR-OFF; then, enter '1' and press the OK key.
            Y developing assembly: COPIER > FUNCTION > INSTALL > INISET-Y
            M developing assembly: COPIER > FUNCTION > INSTALL > INISET-M
            C developing assembly: COPIER > FUNCTION > INSTALL > INISET-C
            Bk developing assembly: COPIER > FUNCTION > INSTALL > INISET-K
            'OK!' is displayed on the screen after completion of this mode.
            18) Execute aging in the following order.
            - Execute 20 sheets of duplexing print for Blue solid color image (A3 or LDR).
            - Execute 20 sheets of duplexing print for Green solid color image (A3 or LDR).
            - Execute 20 sheets of duplexing print for Red solid color image (A3 or LDR).
            - Execute 10 sheets of duplexing print for solid black image in monochrome mode (A3 or LDR).
            - Execute 20 sheets of duplexing print for solid white image in monochrome mode (A3 or LDR).
            19) Execute the following Service Mode: COPIER > FUNCTION > MISC-P > P-PRINT; then, store the output
            papers. If there is any previous P-PRINT output, replace it with the new one.
            20) Escape the Service Mode and select User Mode > Auto Gradation Correction. Execute auto gradation correction
            (full adjust) according to the instruction on the display.
            • teckat
              • 16083
              Re: imgepress c1
              • zoraldinho
                • Mar 2008
                • 5009
                Re: imgepress c1
