Jam report IR5055
  • aabarnes1
    • Mar 2009
    • 620
    Jam report IR5055
    Hi people, dont know canons much, could somebody please tell me how to print off or view the jam report/status on IR5055N, thanks a million.
    Grant me the serenity to accept the things I cannot change.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Re: Jam report IR5055
    1.Call Canon trained tech.
    2.Go to service mode:settings/28
    simultaneously/settings/copier/jam
    Code Jam
    01xx delay jam
    02xx stationary jam
    0Axx residual jam
    0Bxx cover open jam
    Code Sensor Notation
    xx01 registration paper sensor PS29
    xx02 write check sensor PS28
    xx03 vertical path 1 paper sensor PS24
    xx04 vertical path 2 paper sensor PS25
    xx05 vertical path 3 paper sensor PS26
    xx06 vertical path 4 paper sensor PS27
    xx07 right deck pull-off sensor PS32
    xx08 left deck pull-off sensor PS33
    xx0B right deck retry sensor PS19
    xx0C left deck retry sensor PS20
    xx0D cassette 3 retry sensor PS21
    xx0E cassette 4 delivery sensor PS22
    xx0F fixing claw jam sensor PS4
    xx10 inside delivery sensor PS35
    xx11 outside delivery sensor PS36
    xx12 delivery jam sensor PS46
    xx13 reversal sensor 2 PS38
    xx14 delivery sensor 1 PS37
    xx15 duplexing paper sensor PS34
    xx16 duplexing pre-registration sensor PS30
    xx17 fixing outlet sensor PS52
    xx18 fixing inlet sensor PS51
    1001 inlet path sensor delay jam
    1002 punch path sensor feed delay jam
    1003 escape path sensor feed delay jam
    1004 delivery path sensor delay jam
    1101 inlet path sensor stationary jam
    1102 punch path sensor feed stationary jam
    1103 escape path sensor feed stationary jam
    1104 delivery path sensor stationary jam
    1200 finisher timing jam
    1300 power-on jam1400 door open jam
    1500 stapler staple jam
    1644 punch jam
    1645 punch residual jam
    1791 saddle feed path sensor feed delay jam
    1792 saddle delivery sensor feed delay jam
    1793 saddle inlet sensor feed delay jam
    17A1 saddle feed path sensor feed stationary jam
    17A2 saddle delivery sensor feed stationary jam
    17A3 saddle inlet sensor feed stationary jam
    1786 saddle stapler staple jam
    1787 saddle power-on jam
    1788 saddle door open jam
    17B1 document registration sensor delay jam
    17B2 reversing inlet sensor delay jam
    17B3 reversing sensor delay jam
    17B4 reversing timing sensor delay jam
    17B5 deacceleration timing sensor delay jam
    17B6 separation timing sensor delay jam
    17B7 folding position accuracy sensor delay jam
    17B8 upper stopper assembly path sensor delay jam
    17B9 delivery 1 sensor delay jam
    17BA delivery 2 sensor delay jam
    17BB 3-fold tray empty sensor delay jam
    17C1 document registration sensor stationary jam
    17C2 reversing inlet sensor stationary jam
    17C3 reversing sensor stationary jam
    17C4 reversing timing sensor stationary jam
    17C5 deacceleration timing sensor delay jam
    17C6 separation timing sensor stationary jam
    17C7 folding position accuracy sensor stationary jam
    17C8 upper stopper assembly path sensor stationary jam
    17C9 delivery 1 sensor stationary jam
    17CA delivery 2 sensor stationary jam
    17CB 3-fold tray empty sensor stationary jam
    17D1 inserter paper absent jam
    17D7 inserter power on jam
    17D8 inserter door open jam
    jam.jpgclick to enlarge
    Touch the appropriate notation for details.
    [1] To go to the previous page.
    [2] To go to the next page.
    [3] To find out the order of jams.
    [4] To find out the type of jam.
    [5] To find the sensor in question.
    [6] To go to the previous Jam screen.
    [7] To go to the next Jam screen.
    <No.> Indicates the order of jams; 1 through 50 (the higher the number, the older the jam).
    <DATE> indicates the date of occurrence of the jam in question.
    <TIME1> indicates the time of occurrence of the jam in question.
    <TIME2> indicates the time of jam recovery.
    <L> indicates the location of the jam in question; 0 to 2 (0: copier; 1: feeder; 2: finisher).
    <CODE> indicates the jam code in question.
    <P> indicates the source of paper.
    1: cassette 1
    2: cassette 2
    3: cassette 3
    4: cassette 4
    5: side paper deck
    6: manual feed tray
    7: duplexing assembly
    <CNTR> indicates the reading of the soft counter used for the source of paper.
    <SIZE> indicates the size of paper.
    • aabarnes1
      • Mar 2009
      • 620
      Originally posted by zoraldinho
      1.Call Canon trained tech.2.Go to service mode:settings/28 simultaneously/settings/copier/jamCode Jam01xx delay jam02xx stationary jam0Axx residual jam0Bxx cover open jamCode Sensor Notationxx01 registration paper sensor PS29xx02 write check sensor PS28xx03 vertical path 1 paper sensor PS24xx04 vertical path 2 paper sensor PS25xx05 vertical path 3 paper sensor PS26xx06 vertical path 4 paper sensor PS27xx07 right deck pull-off sensor PS32xx08 left deck pull-off sensor PS33xx0B right deck retry sensor PS19xx0C left deck retry sensor PS20xx0D cassette 3 retry sensor PS21xx0E cassette 4 delivery sensor PS22xx0F fixing claw jam sensor PS4xx10 inside delivery sensor PS35xx11 outside delivery sensor PS36xx12 delivery jam sensor PS46xx13 reversal sensor 2 PS38xx14 delivery sensor 1 PS37xx15 duplexing paper sensor PS34xx16 duplexing pre-registration sensor PS30xx17 fixing outlet sensor PS52xx18 fixing inlet sensor PS511001 inlet path sensor delay jam1002 punch path sensor feed delay jam1003 escape path sensor feed delay jam1004 delivery path sensor delay jam1101 inlet path sensor stationary jam1102 punch path sensor feed stationary jam1103 escape path sensor feed stationary jam1104 delivery path sensor stationary jam1200 finisher timing jam1300 power-on jam1400 door open jam1500 stapler staple jam1644 punch jam1645 punch residual jam1791 saddle feed path sensor feed delay jam1792 saddle delivery sensor feed delay jam1793 saddle inlet sensor feed delay jam17A1 saddle feed path sensor feed stationary jam17A2 saddle delivery sensor feed stationary jam17A3 saddle inlet sensor feed stationary jam1786 saddle stapler staple jam1787 saddle power-on jam1788 saddle door open jam17B1 document registration sensor delay jam17B2 reversing inlet sensor delay jam17B3 reversing sensor delay jam17B4 reversing timing sensor delay jam17B5 deacceleration timing sensor delay jam17B6 separation timing sensor delay jam17B7 folding position accuracy sensor delay jam17B8 upper stopper assembly path sensor delay jam17B9 delivery 1 sensor delay jam17BA delivery 2 sensor delay jam17BB 3-fold tray empty sensor delay jam17C1 document registration sensor stationary jam17C2 reversing inlet sensor stationary jam17C3 reversing sensor stationary jam17C4 reversing timing sensor stationary jam17C5 deacceleration timing sensor delay jam17C6 separation timing sensor stationary jam17C7 folding position accuracy sensor stationary jam17C8 upper stopper assembly path sensor stationary jam17C9 delivery 1 sensor stationary jam17CA delivery 2 sensor stationary jam17CB 3-fold tray empty sensor stationary jam17D1 inserter paper absent jam17D7 inserter power on jam17D8 inserter door open jam[ATTACH=CONFIG]11504[/ATTACH]click to enlargeTouch the appropriate notation for details.[1] To go to the previous page.[2] To go to the next page.[3] To find out the order of jams.[4] To find out the type of jam.[5] To find the sensor in question.[6] To go to the previous Jam screen.[7] To go to the next Jam screen. Indicates the order of jams; 1 through 50 (the higher the number, the older the jam). indicates the date of occurrence of the jam in question. indicates the time of occurrence of the jam in question. indicates the time of jam recovery. indicates the location of the jam in question; 0 to 2 (0: copier; 1: feeder; 2: finisher). indicates the jam code in question.
      indicates the source of paper.1: cassette 12: cassette 23: cassette 34: cassette 45: side paper deck6: manual feed tray7: duplexing assembly indicates the reading of the soft counter used for the source of paper. indicates the size of paper.
      Cheers mate, ur a star!
      • spectraindo
        • May 2008
        • 313
        To print JAM History :
        ADD FUNCTION - 28 - ADD FUNCTION - COPIER - FUNCTION - MISC-P - HIST-PRT - OK.
        • aabarnes1
          • Mar 2009
          • 620
          Originally posted by spectraindo
          To print JAM History :ADD FUNCTION - 28 - ADD FUNCTION - COPIER - FUNCTION - MISC-P - HIST-PRT - OK.
          Thank you very much
          • spectraindo
            • May 2008
            • 313
            Your welcome
