Canon ir3225 running slow, printing, copying and control panel
Re: Canon ir3225 running slow, printing, copying and control panel
If the system software downloads very slow, the Nic may not be configured correctly in the laptop. Complete the following path on the laptop, to see if the Network Interface Card (NIC) is configured correctly.
My Network Places > Properties > Local Area Connections > Properties > Configure > Advanced. Select Speed + Duplex to check the communication speed of the NIC. Be sure to set the speed to "Auto" or "100 Mb Full".
Below is a screen shot with arrows pointing to the Speed + Duplex values.
**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Thank-You Teckat
All your info is spot-on, One more question, can I use Vista home, or Windows 7 yet to install SSW.In your experience from start to finish with installing new harddrive to low format hard-drive to install SSW sound right in a perfect world, 1 hour ?
Thanks againGive a man a fish he eats for a day,Teach a man to fish he eats for a Life time.Comment
iR3225 3230 3235 3245_TP10_093b-2.pdf**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
