iRC2880i bad copies
  • iRC
    Summer trainee!
    • 96
    iRC2880i bad copies
    I'm having some issues with one 2880. The image is good when printing, but all copies are quite dark. Before I'm fitting a new scanner unit I must ask: Is there anything else left to do? I'm remembering that there is some adjustment at the service mode...
    Thanks for the suggestions!
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: iRC2880i bad copies
    1) Place paper (of the type most often used by the user) on the copyboard
    glass, and close the DADF.
    2) Touch the following notations in sequence to bring up the Adjustment
    screen:
    1 COPIER
    2 FUNCTION
    3 CCD
    3) Press [DF-WLVL1] to highlight.
    4) Press [OK].
    Automatic adjustment starts; if it ends successfully, the screen shows
    [OK!].
    5) Remove the paper from the copyboard glass, and place it on the original
    tray of the DADF.
    6) Press [DF-WLVL2] on the touch panel to highlight.
    7) Press [OK].
    - The machine executes auto adjustment (duplex stream reading).
    - When the adjustment ends normally, the machine indicates 'OK!' on the
    screen.
    8) Press the Reset key twice to end service mode.
    9) Turn OFF the power switch on the operation panel and main power switch
    of the host machine in or-der
    • teckat
      • 16083
      CLEAN OPTICS/COPY GLASS TOP>UNDERSIDE
      Auto Gradation Adjustment Plain
      Full Adjust: Automatic after the machine prints and scans three sets
      of test prints
      Quick Adjust: Press [Start]
      Automatic Gradation Correction
      1) Clean the machine's copyboard glass.
      2) Place A3, A4, 11X17, or LTR paper in the
      cassette.
      3) Press the [Additional Function].
      4) Make the following selections: [adjust/clean] > [auto gradation correction] > [full correction] >
      [test print]
      - The test print 1 will be printed out.
      5) Place the printout of the test print 1 on the copyboard glass as instructed on the control panel
      screen.
      6) Close the copyboard cover/ DADF.
      7) Press [start to read].
      - The machine reads the printout of the test print 1.
      - When a message appears prompting you to remove the test print, remove the printout of the
      test print 1 from the copyboard glass.
      8) Press [test print 2].
      - The machine prints out the test print 2.
      9) Place the printout of the test print 2 on the copyboard glass as instructed on the control panel
      scan.
      10) Close the copyboard cover/ DADF.
      11) Press [start to read].
      - The machine reads the print out of the test print
      2.
      - When a message appears promoting you to remove the test print, remove the printout of the test print 2 from the copyboard glass.
      12) Press [test print 3].
      - The machine prints the test print 3.
      13) Place the printout of the test print 3 on the copyboard glass as instructed on the control panel
      screen.
      14) Close the copyboard cover/ DADF.
      15) Press [start to read].
      - The machine reads the printout of the test print 3.
      - The machine issues a message to indicate that it has completed full correction. In response,
      remove the printout of the test print 3 form the copyboard glass.
      16) Press the Reset key once to end user mode.
      PASCAL
      Adjustment for auto gradation correction control
      COPIER>ADJUST>PASCAL
      OFST-P-Y/M/C/K Use it to apply offset adjustment on the test print reading signal (Y) for PASCAL
      control at time of auto gradation correction (full).
      Method of Adjustment
      - a higher setting will make the image darker after auto gradation correction (full).
      Range of Adjustment: -128 to +128 [Factory default/After RAM clear: 0
      • iRC
        Summer trainee!
        • 96
        screen:
        1 COPIER
        2 FUNCTION
        3 CCD
        4) Press [OK].
        [OK!].
        tray of the DADF.
        7) Press [OK].
        screen.
        Great! That's what I was looking for. I'll try that on monday.
        Teckat: The auto gradation adjustment is done several times; no luck.
        Thanks Guys!
        • zoraldinho
          • Mar 2008
          • 5007
          Good luck
          • Tim C
            • 167
            I recently had the same problem...did all that you did
            as well. Only to find out the customer ran out of toner and was dumb enough to
            put the waste toner back in the BLK toner ctg. What a friggin mess to deal with. Ended up replacing the Black drum unit.
            Have you tried running a copy in each color ?
            • iRC
              Summer trainee!
              • 96
              I've totally forgot to answer to this thread. Sorry about that!
              My problem was cleared with the CCD -adjustment (lucky me). But it's nice to know that there's someone even dumber than me . I've never ever heard that someone has emptied a color copier's waste toner back to the cartridge. Oh no.
              • teckat
                • 16083
                on the Old NP120/125/210 and others,
                have seen this dumping of waste toner in the toner holder/customer paid for parts-labor
                turned the DEV.Cylinder into a brick
                • Tim C
                  • 167
                  They Paid over $800 for that mistake..
                  • charm5496
                    • 2387
                    that a boy....time is money and customers will never learn or even care to try and learn unless you get their attention!!!
