IRC5800 Help
  • acollard83
    • Mar 2025
    [Misc] IRC5800 Help
    I just received a few Canon Image Runners, all have Error E602-0001. I've looked through the forums here and have found that issue to mainly be hard drive. I did push buttons 1&9 on 2 of the units and both went to download mode. I figure I'll try and format the hard drive and install the firmware before buying new hard drives. I have version 3.22E of the SST, but thats all I have. I think I have an idea of what I need to do, but I need the image files, I think. If anyone can get those to me, or even offer advise in this venture it would be greatly appreciated. I have an iRC5800, an IR2270 and an IR3300.
  • teckat
    • 16092
    Re: IRC5800 Help
    u need the FIRMWARE for all those machines loaded in SST
    iR2270 ift.file is Encrypted- and not Editable/ need same HDD Model that is in printer or a Canon OEM HD
    iR3300 is Editable for HDD
    iR5800 is Editable for HDD
    see pdf>>>>>SST HDD Not Found.pdf
    • acollard83
      Re: IRC5800 Help
      see pdf>>>>>[ATTACH]11516[/ATTACH]
      Thank you. How/where would I get the files?
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 4972
        Re: IRC5800 Help
        Canon trained tech have.
        Practice makes perfect
        If you want something done right, you have to do it yourself
