IR C3170i ADJUSTING GRADATION PROBLEM
  • sreerama9
    [Misc] IR C3170i ADJUSTING GRADATION PROBLEM
    I HAVE IR C3170i COLOUR MACHINE I AM GETTING ADJUSTING GRADIATION FOR EVERY COPY OF O/P AND I AM LOOSING TONER ALSO WITH THIS PROBLEM IS THERE ANY SOLUTION FOR THIS COLOUR CATRIDGES ARE ROTATING FOR ADJUSTING GRADIATION.
  • londonboy
    • Jul 2011
    • 10
    Re: IR C3170i ADJUSTING GRADATION PROBLEM
    The way you can correct this is to reset the DC CON, as your dev settings have gone all out of sync.
    This will reset all the colour devs back to standard setting and the mc will adj its self to match the devs accordingly.
    There is a chance the devs are knackered all depends how long its been doing it.
    Bear in mind this also resets drum, fuser, bk dev counts. So take a note of them and re-enter.
    Good luck
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      Throw this piece of crap in to dumpster.
      • londonboy
        • Jul 2011
        • 10
        My response to this is the last thing you after you tried all the obvious stuff like drum and patch sensor etc
