Canon IRC 3200 E732-001 Error Code
  • tinnyjay
    • Oct 2009
    • 663
    I tried to reconnect reader unit,but the problem is still present.
    I am thinking of installing the firmware,but the problem is that i cannot put fixed IP to the copier to make a network installation.
    Somebody experienced with this problem help me?
    "Who loves the roses,must also bear thumbs"
    • 16083
    Re: Canon IRC 3200 E732-001 Error Code
    If the Reader is disconnected from the Printer/or if the Reader unit is unplugged to diagnose an E732 code (reader communication error),a E732 code will result.
    Once the Reader is disconnected the logic on the MAIN-Controller is changed to a "0".
    The copier is now set up to be a Printer only, and will not recognize the Reader.
    To correct this, you must enter service mode, COPIER>OPTION>BODY>W/SCNR and set that to "1".
    Then you must turn the copier off, then on.
    or
    A defective DC Fuse PCB can cause the error code.
    An intermittent loss of voltage to the Reader Unit will caused the machine to code out.
    imageRUNNER C3200
    How to troubleshoot the DC-fuse PCB or a missing voltage in the machine.
    When a over-current or a short to ground occurs in the machine such as a motor binding or a wire shorted to the frame of the machine, a fuse on the DC-fuse PCB should open to prevent damage to the machine. The DC-fuse PCB is located in the rear lower left of the machine mounted on the DC-power supply. The circuit diagram for the power distribution is found on page 105 & 106 of the technical reference guide.
    The fuse, voltage, connectors, and the destination of the voltage is listed below.
    Fuse-------Voltage----Connector Destination Connector
    3.3 Volts DC have pink wires
    FU11 3.3vdc J59-1 Power distribution PCB J1502-1
    FU11 3.3vdc J59-2 Power distribution PCB J1502-2
    FU13 3.3vdc J60-3 Power distribution PCB J1501-3
    FU13 3.3vdc J60-4 Power distribution PCB J1501-4
    FU14 3.3vdc J61-5 Fax G3-G4 J560-3
    FU14 3.3vdc J61-6 Fax G3-G4 J560-4
    FU15 3.3vdc J61-7 Fax G3-G4 J560-6
    FU22 3.3vdc J64-9 DC controller J100-9
    FU22 3.3vdc J64-10 DC controller J100-10
    5 Volts DC have brown wires
    FU16 5vdc J61-13 Fax G3-G4 J560-11
    FU17 5vdc J60-1 Power distribution PCB J1501-1
    FU17 5vdc J61-11 Fax G3-G4 J560-9
    FU17 5vdc J61-12 Fax G3-G4 J560-10
    FU23 5vdc J71-5 DC controller J106-1
    FU27 5vdc J68-3 Duplex devivery PCB J440-3
    12 Volts DC have orange wires
    FU12 12vdc J59-5 Power distribution PCB J1502-5
    FU18 12vdc J60-8 Power distribution PCB J1501-8
    FU31 12vdc J64-7 DC controller J100-7
    14 volts DC
    FU32 14vdc J65-1 NO output
    24 Volts DC have red wires
    FU20 24vdc J62-1 H3 Fixing unit J802-4
    FU21 24vdc J64-1 DC controller J100-1
    FU21 24vdc J64-2 DC controller J100-2
    FU24 24vdc J74-1 Power distribution PCB J1509-2
    FU24 24vdc J66-1 Fax PCIP J559-1
    FU25 24vdc J67-2 Reader J565-1
    FU25 24vdc J67-3 Reader J565-2
    FU26 24vdc J68-1 Duplex delivery PCB J440-1
    FU28 24vdc J70-1 HV2 sub PCB J91-1
    FU29 24vdc J70-3 Drum ITB motor J93-1
    • tinnyjay
      • Oct 2009
      • 663
      or
      imageRUNNER C3200
      14 volts DC
      Thank you so much,now solved.
      Just a small problem with Reader Unit connector
        • 16083
