This may be one of those TIP's.
Both decks are not feeding very well. I went over last week, pulled the feed head for the right
deck and put two sheets of paper between the feed and sep rollers and pushed the gear. Both
sheets fed together. I saw the torque limiter turn in the feed direction. So I swapped that
limiter with the one in tray 4, the least used tray. (The spring for the sep roller is set at the
lowest setting per the manual to reduce multi-feeds.) Same test the sheets separated.
Test tray four, the sheets separated.
It would multi-feed 3-4 sheets in a 15 page run. When I finished I ran 40-50 pages and so did
the customer. Alls well right?
They call back with the same problem today. I did clear all the jam codes so I will have some
current codes which I will gladly share tomorrow.
As I recall all the feed rollers had less than 10K on the counters.
On the back wall of the machine behind the left feed deck, there is a white lever. What purpose does
it serve? It moves easily back and forth. Is it attached to a solenoid or something?
Any suggestions welcome
Dr
