4570 Finisher Q3, top tray wont cycle up
  • euro scott
    • 127
    Help, my Canon tech is on vacation so im running calls and have this finisher that still operates but the top tray doesnt cycle up, when you manually lift it goes down but doesnt care for up, went to dip switches on control board and neither tray will cycle.. Any suggestions?
    Scott
    • 16083
    Re: 4570 Finisher Q3, top tray wont cycle up
    Scott
    Check if the flag for PI41 (Tray 1 Paper Surface Sensor) is stuck. Remove the cover around the flag, check if the flag moves freely. Refit the cover & check if flag moves freely -
    • charm5496
      • 2387
      I'm with Teckat on this one. Most of the time those flags get stuck or break off causing the issue.
      • mrfixit51
        Lead Service Technician
        • 1975
        I can't recall if this model can go into Limited Functions mode or not, might be something to at least check. Additional Functions, then the tab in upper left of display, (either Copy or Common, can never remember which is which till I am stand in front of a copier ;-) ), scroll down till the last few pages and look for Limited Functions Mode, it should be OFF, if it is ON enter the mode, turn it off, and cycle power on the copier...
          • 16083
          imageRUNNER 2270 / 2870 / 3570 / 4570
          "Finisher Cannot be Used" appears after the finisher experiences an error and the "Limit Functions" option is selected on the display. By selecting Limit Functions, the machine will operate properly except for the use of the Finisher. After the malfunction or error code with the finisher has been resolved, you must reset the "Limited Functions" option. To do this, go into Additional Functions>Common Settings>Limited Functions Mode and select "OFF".
          • euro scott
            • 127
            Thanks Guys, it was the switch ! sounded like it had something wedged in it as it made a noise of something falling down when started inspecting it..
            You Guy's Rock !!!
              • 16083
              You Guy's Rock !!!
              ELVIS.jpgRock n' Roll yeah'
