Scanning to email (gmail) Canon ImageRunner Advance C2020
  • ELUNO
    • Jun 2025
    I've been trying unsuccessfully to scan and send files to emails using our copier.
    I've searched and read different threads on different machines and I know what the details must be set to in order to use gmail's smtp server. I have done this but I have no idea where I can change the port for SSL information.
    Any help on how to set this up in this machine would be appreciated.
    Thanks.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5006
    Re: Scanning to email (gmail) Canon ImageRunner Advance C2020
    Setting for communicate SSL
    To communicate SSL, this machine can register the key pair and the certificate. The key pair
    and the server authentication book self-signed by default have registered as DefaultKey.
    The default key used by the following settings can be changed.
    - Remote UI
    - MEAP Settings
    - IPP Print Settings
    - Device Information Delivery Settings
    - Dept. ID Management Password Confirmation
    - E-Mail/I-Fax: Authent./ Encryption Settings
    Settings/Registration > Preferences > Network > TCP/IP Settings > SSL Settings
    In the case of IPPS print from Windows Vista / Windows 7, the Common Name should be the
    IP address of the host machine when generating SSL key.
    Settings/Registration > Management Settings > Device Management > Certificate Settings >
    Generate key > Generate SSL Key
    • ELUNO
      Thanks!
      • zoraldinho
        • Mar 2008
        • 5006
