IR4570 fixing assy
  • LennoxD
    • Sep 2011
    • 82
    IR4570 fixing assy
    Anyone has tried to use the fixing film (FM2-0358-000) in the ir4570?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Re: IR4570 fixing assy
    I believe it's not the same connector but i need to check.
    • zoraldinho
      • Mar 2008
      • 5018
      Yeap.No way.
      • TEC DOG
        • Sep 2011
        • 113
        FM2-0293-000 FIXING FILM UNIT
        iR2270/iR2270F/iR2230/
        iR2230F/iR2870/iR2870F
        100V
        FM2-0358-000 FIXING FILM UNIT iR2270/iR2870 120V
        FM2-0359-000 FIXING FILM UNIT iR2270/iR2870 230V
        FM2-1792-000 FIXING FILM UNIT iR4570/iR4570F/iR3570/
        iR3570F 100V
        FM2-1793-000 FIXING FILM UNIT iR4570/iR3570 120V
        FM2-1794-000 FIXING FILM UNIT iR4570/iR3570 230V
        • totoro
          • 568
          I have done it once. I opened a fixing film unit for the 4570 and it had the wrong connector on it so I assume it was for the 2270. I did not have another 4570 fixing film and when I looked at them it looked like they were the same except for one of the connectors. The customer was desperate so I switched the connectors and it worked. This was for 120v. Now I don't know if this was because they put the wrong connector on this fixing film unit or because they are the same except for the connector so try at your own risk.
          Totoro
          • LennoxD
            • Sep 2011
            • 82
            @totoro. thanks. I will try what you did.
            • LennoxD
              • Sep 2011
              • 82
              @totoro. thanks very much. changing the connector works.
              • mrfixit51
                Lead Service Technician
                • Oct 2008
                • 1975
                Fixing Film Assembly's
                120v Fixing Film Assembly's
                FM2-0358-000 iR2270/2870/3025
                FM2-1793-000 iR3570/4570/3030/3035/3045
                FM3-7068-000 iR3225
                FM3-7070-000 iR3230 - 3235 - 3245
                • northernlife
                  • Sep 2011
                  • 847
                  lol found this out today the hard way. 22/28 is a 4 pin connector and 35/45 is a 3 pin. At least the films are the same if that's all it needs.
                  • Simons
                    • Jun 2008
                    • 490
                    Id love to hear more experience about doing this. Mainly for emergency purposes. I knew the film was the same but never tried swapping connectors. Funny, anyone else?
                    • northernlife
                      • Sep 2011
                      • 847
                      err didnt mean to swap the connector but the film itself if that's all it needs to buy you some time.
                      • mrfixit51
                        • Oct 2008
                        • 1975
                        I just carry the 4 film assemblies in my car stock, far easier and faster than trying to wrestle with the connectors...
