I have installed wlan card in iR3225 and configuring it with 802.1X/EAP Security setting.it is giving 'root ca certificate error'.I have tried installing system software v42.01 but still no luck.please help how can i get this root ca certificate bypass or installed.
root CA certificate error in iR3225 secutity mode is 802.1X/EAP(WLAN CARD)
Re: root CA certificate error in iR3225 secutity mode is 802.1X/EAP(WLAN CARD)
For detailed instructions, see the attached file 'certificate_key.pdf'.
* Note - Any key pairs or certificates imported onto the copier must be registered to be used. You can only register key pairs that use the RSA algorithm (the DSA algorithm is not supported).
To delete a key pair or certificate, you will need to disable SSL for all the protocols that support SSL on the copier (ex. RUI, IPP, SMTP, POP, Device Information Delivery, MEAP).**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
imageRUNNER 3230 / 3225 / 3235 / 3235i / 3245 / 3245i
Wireless Support for imageRUNNER 3230 / 3225 / 3235 / 3235i / 3245 / 3245i
These devices support wireless connectivity and what are the specifications?
This model series supports wireless with the inclusion of the Wireless LAN Board-A1 (item number 2727B001AA).
Please note that in order to install the Wireless LAN Board A1, the Expansion Bus Board E1 (item number 2724B001AA) will have to be installed into the device as well.
The specifications are as follows.
Before registering the new imageRUNNER 3425 Series System Software v42.01.02, uninstallv20.01 installs correctly.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
I did it with USB Drive and registering the firmware in SST first time.Comment
certificate_key.pdf
did u read this pdf. above ???
& below>>iR3225 TP10_093b.pdf
u used a USB to install the updated ver. firmware in printer -**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
