ir6570 error E000584-8001
  • Dedotch
    • Oct 2008
    • 40
    Can anyone tell me what this error is? It is random and goes away when I re-power up. That page is torn out of my book.
  • teckat
    • 16083
    Re: ir6570 error E000584-8001
    E584 There is a shutter unit error. (finisher)
    8001 / The shutter open sensor fails to go off.
    (The shutter does not close.)
    8002/The shutter open sensor does not go on.
    (The shutter does not open.)
    1. Check the shutter home position sensor.
    Is it normal ?
    2. Check the wiring between the finisher controller PCB and the stack feeding motor and between the finisher controller PCB and the shutter open/close clutch.
    Is it normal ?
    3. Is there a fault in the shutter mechanism?
    4. Try replacing the stack edging motor and the shutter open/close clutch. Is the problem corrected?
    Stack Ejection Motor M102 (4K1-1106-000)
    E584-8001 may be remedied by replacing the Shutter Clutch CL101. The part number for the clutch is FH6-5101-030. Both CL101, and CL102 are the same clutch, and may be swapped with each other to facilitate troubleshooting.
    click on pic to view
