canon 5065 error e025 001
  • asser145
    • Mar 2011
    • 40
    i have a canon with error e025-0001
    i don`t know whats happend
    what is the solution??
    tnks
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: canon 5065 error e025 001
    Are you a tech? There is a toner feed motor over-current detection error, there is a toner bottle motor connection detection error.Check the connector and the motor.
    • asser145
      • Mar 2011
      • 40
      i'am tech, but i never seen this machine
      • gensys
        • Jan 2011
        • 323
        Check the connector for any fault in
        connection.
        Replace the motor.
        The Road will be Mastered by >>> the Going...
        • asser145
          • Mar 2011
          • 40
          is this motor ???
          • zoraldinho
            • Mar 2008
            • 5007
            Originally posted by asser145
            [ATTACH=CONFIG]11665[/ATTACH]
            is this motor ???
            • asser145
              • Mar 2011
              • 40
              is the motor number 4 of the pic. tnks.
              I put the "" engine failure "" in another machine and works well. but I put the motor of the machine that works well on the machine and still funiconar broken, do not think that is the driving
              tnks
              • mrfixit51
                Lead Service Technician
                • Oct 2008
                • 1975
                The customer may have wedged the toner bottle into the machine trapping the fin on the bottle on the wrong side of the tray. This is what initiates the problem, then if reset numerous times , the DC controller can get fried from the over-current situation of trying to turn the bound up bottle. I have on occassions had to replace both the motor and the controller, as a bad motor can take out the controller board.
                If you are really lucky, just re-seating the bottle correctly has taken care of the issue on a few occasions for me...
                • Canuck
                  Tech Specialist
                  • 1713
                  replace the motor and replace F9 on the Dcon. Its a 2 amp 120v fuse,get fancy with your soldering iron
                  • vigour
                    • Aug 2010
                    • 1038
                    e025-001 refers to M9 FK2-0183. it looks like a small bulb, with transparent plastic around it.
                    It is easier, cleaner, and not much more costly to replace FM2-3029 sub-drive assembly.
                    -turn copier off
                    -open toner door
                    - turn copier on
                    it should start without error code, if your dc controller is still good
                    it will make copies till the dev calls for toner again.
                    remove dev
                    remove hopper
                    assembly comes out with 3 or 4 screws.
                    after installing motor or assembly ,don't forget to plug both sides in.
                    • gensys
                      • Jan 2011
                      • 323
                      is this motor ???
                      The iR very dirty. The mashine needs to be kept always clean. Digital copiers not love a dust ...
                      • asser145
                        • Mar 2011
                        • 40
                        vigor is as it says, opening the door does not fail, but when it makes copies, and makes 5 returns to give the error.
                        now ask the dc motor.
                        I will tell you
                        • asser145
                          • Mar 2011
                          • 40
                          the motor has arrived, and operates the machine
                          thanks to all
