Please advise what error code E808 means and how to fix. Thanks
IR2016 E808 Error code
Re: IR2016 E808 Error code
Error :
Intermittently, an E808 error code is displayed on the control panel.
Workaround :
In this case, installing a DC Controller with version 3.02 corrected the error
or see below
imageRUNNER 2016 / 2020 / 2016i / 2020i
Clear error code E808------
The error has been caused by one of the connectors for the fixing assembly not being plugged in when the unit is powered on. This has happened after replacing the fixing assembly and not plugging in the connector or when trouble shooting on the machine for some other problem and leaving the connector unplugged. The connector is to the thermistors in the fixing assembly. In the general circuit diagram it is connector J255DH.
The connector is a six pin connector with two yellow and two orange wires going into it. It is the top connector located above and to the right of the fixing assembly. It is behind a cover on the side of the machine.
To clear the E808 code unplug the machine for about 10 minutes. If the thermistors are bad the code will appear but will not reset until the fixing film assembly is replaced. The part number for the fixing film assembly is FM2-3346-000.
Last edited by teckat; 09-08-2011, 12:30 AM.**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
good luck
here are the pics/ sometime they don't display properly
click on pics for better view
thermistor.jpg**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
