Hi Guys!
I've got a problem with an IR1022A . it has been installed on the computer with UFRII and works perfectly as a printer then I tried to install it as a scanner with the IR Toolbox 4.9 of course thruogh an USB cable. After I installed the toolbox and try to config the buttons in the application, it says the supported scanner is not installed.
I'd done before several times installing with Ir10XX on usb cable scanning but never had this kind of problem.
So I made an ALL Clear....nothing happened.
I updated the firmwares from v61 to v68 but nothing happened also.
What should I do?... The customer uses XP.
Someone told me I should install a PCL driver for the machine ( like its a pcl printer even that PCL option doesn't inlcude this machine) so I installed it as a pcl driver...but it wasn't good idea...nothing happened.....
What can be the problem?
Thank you !
Thank you !
